Greetings everyone:
Which of the two would be less likely to have blade play (vertical and side to side) in it? It might influence my potentially purchasing one of them "sight unseen" over the internet.
Thanks in advance.
There is usually a LITTLE play in a knife, after a month or so my para develops blade play and I usually just tighten the pivot a little to get rid off it. To say a knife will have no blade play and if it does sends it back is a little bit of an over statement.
Do you use them much?
And almost every knife comes with a little bit of play, by blade play I mean I can make the blade move up or down or side to side when the knife is open.
No, they were all safe queens. I don't believe in using my knives.I've used my millies extensively outside, inside, breaking down doubled cardboard boxes, etc. The para sees a bit less, but considering one's SE I use that as a loaner / scrapper knife most of the time.
Holding the tip and rocking the pivot under pressure will produce some "give" but it's not play. None of my knives have play.
What I meant by the question if you used them regularly or not is that some knives will develop a little bit of play, and I just checked my para and it has a little bit of side to side blade play. I appreciate your smart remark though :thumbup:
I remember for pinned FRN spydies that a little tap on the pins/pivot would get rid of the play?
in any case, my Caly and Para have no play but I'm using them with a lot of torque, just regular cutting - food, paper, cloth, webbing
Thank you everyone. I'll need to mull it over more!
