- Dec 4, 2005
When I re-profile a blade I often have to use quite a bit of pressure and this creates a burr that is pretty heavy and strong. How should I remove such a burr? Traditional methods do not seem to work. Suggestions?
Thanks so far for your advice. I sharpen on a 1x30 belt sander. The first belt, especially during re-profiling, is 120 grit. I usually deburr with an 8 inch paper wheel, although I have tried everything that I can think of or have been told would work as a de-burring tool as well, with less than satisfactory results.
*waits for wow’s retort*
120 grit belt sander.
Machine sharpening is a bit different but the same rules still apply. Lighter pressure and in your case fresh belts of quality abrasive are a BIG step in decreasing burr size.
Second, you would benifit from a deburring stage in your sharpening. I go Belt, fine scotch brite wheel, surgisharp leather wheel when i machine sharpen and burrs are never a problem.
Here's my question.
I know a lot of folks like to increase their angle 4 or 5 degrees per side, and do a few passes to shear off the burr that way.
Doesn't a microbevel also create another "micro burr" ?
Here's my question.
