sharp_edge
- Jul 30, 2015
I got my first CRK couple of days ago. It is a large Sebenza 21. It is a user but in great condition (I am not selling it now). Now I know why people give high remarks to this knife. It is simple, slim, and I can see it is also very functional. The building quality is superb.
I do have couple of questions that I hope folks on this subforum can help. My first question is about sharpening. The knife can still cut print paper but it is not up to the sharpness level of my other knives. The knife has a convex edge, which I assume is how it was set up at factory? Should I keep the convex edge when sharpening? I usually use a guided system, which will produce a V shaped edge. Will that degrade the performance of the knife? What would be the better dps?
My second question is about the lock stickiness. The lockup is about 60-70% which I read is normal and I have no problem with that. When disengaging the lock, however, I can feel resistance. It is audible although it is not making a squeaking noise. This is difficult to describe accurately in words but I hope you get what I mean. Anyway, I can disengage the lockbar easily one-handedly, but it is not as effortlessly as my other frame-lock folders including Hinderer, ZT, and Spyderco (Ti Military). I did try the sharpie/pencil trick, which helped a bit but not much. I also dissembled the knife and cleaned and lubed it thoroughly. My question is: is this lockbar/blade tang tightness normal?
Finally, does anyone feel a bit uncomfortable with the ti scale tip right next to the screw at the end? I guess this has more to do with my not-so-big hand size and I hope over time my hand will get used to it.
