- May 29, 2004
It has been posted here recently by Stacy I believe that a kiln should be heated to about 1200F prior to putting blades in so that the kiln temperature has a chance to stabilize, then ramp up to your target temperature. I have a small kiln that I built for another purpose some years ago, made of 1", 2000 degree kiln board and powered by an oven broiler element. I had never gone above 1000 degrees until yesterday when I set my controller and ran it up to 1475. I went from 80 to 1475 in a little under 25 minutes. If I load the cold kiln with blades and then slam the power to it, is that too fast, will I damage the blades in some way on the heat up? Maybe I am being lazy but I am trying to avoid dealing with the heat from this kiln as much as possible. It is a top loader and it is a bit punishing to get in and out of it so I would prefer to only go into the kiln once to remove the blades instead of having to deal with the heat twice. Any feedback would be appreciated, thanx, Steve B
