Pretty darn simple pocket clip mod for the 110 LT (and possibly for the 112 LT when I pick one up). I'm sure others here have done this, but I thought I'd post it anyway.
1. Sheet metal screw that fits tightly in the lanyard loop
2. LM Wingman pocket clip
3. Knife or drill to make a small divet in the scale for the clip's steadying arm (I used a BM Grip)
Side note: I just grabbed a sheet metal screw I had sitting in my tool box (don't know size) so I had to grind the tip so that it didn't stick out. You should be able to walk into any hardware store and test what screws fit into the lanyard hole. The screw threads should cut into the plastic, so you'll need a screwdriver to twist it through...careful to make sure you put it through straight.
Side note 2: I previously dremeled scallops for finger grooves into the handle, hence the grooves in the pic.
If I remember to, the next time I go to the hardware store I will update which screw I used.
