- Dec 15, 2003
Got it last night from the local knife store. Here are my first impressions:
The blade is centered, there's absolutely no play in the blade in any direction, and there are no burrs in the pivot screws. It came scary sharp.
The blade to handle ratio looks kinda funny, but the grip is great so I wouldn't change the handle.
Overall it's a light package that carries well, though I might prefer for it to sit lower. I do not have a problem with the exposed tang when accessing my RFP. It doesn't feel like it's particularly sharp edge at that point, at least to me.
As I've said before, the compression lock is easy to use and the knife can be closed one-handed without difficulty. I would add that looking at the compression lock and seeing how it works inspires confidence in the lock.
The use of a milled section in the blade fit to the lock bar to hold the blade closed instead of a little ball detent seems very smart. (Has this feature been used before, on the Military or others models?)
Opens smoothly with no "grit."
Yes, the pivot screw is eccentric and can be used to adjust the position of the compression lock bar on the tang. For those of you who had problems with play, this may be the solution.
Seems like a great little, er, medium-sized(?) knife.
