Hi,
Found a lot of interesting threads here, while searching information. I'm very unexperienced in this area and have just performed my first tries to harden steel. In this case actually not even a knife, currently I'm trying to create a tapered reamer. Unfortunately a lot of unknown data and unprecise methods, but I was hoping for some tips or at least guessing for next step. I have made the cutting fluits on the reamer and now want to harden it, then I plan to sharpen the cutting edges and finally use to create two tapered holes in a cast iron part. I'm happy if it survives these two holes, I don't need it to be more long lived.
First of all, I don't even know which steel I have used, picked it up from the scrap bin. However, I did perform a grind spark test, comparing with another known steel. The known steel is a low carbon structural steel (S355J2). Grind sparks from this were quite long and not very "sparky". My unknown steel gave shorter sparks, much more "sparky" (more like fireworks). Based on this I assume I have some sort of high carbon steel.
First I created a small "soup can forge" which I heated by a propane torch. Unfortunately this was not enough to generate an even heat for the complete lenght of the reamer. One end got yellowish (and not magnetic), but the other end was clearly cooler. I did try to quench it anyway, in oil (canola oil). Tried it with a file, and not very surprising the cooler end was still soft. The other end felt good though, I was satisfied with the hardness.
For the second test I made a larger forge, heated by coal and blew air through the bottom of the forge (used air compressor). Checked when it was not magnetic and quenched in canola oil again. Tried with the file, it felt quite okay. Couldn't feel any difference between one side and the other, but it felt a little little bit softer than the best side from the first try. However, I judged it good enough and put it in the oven for tempering. Regular kitchen oven, 200 degrees celsius (=392 degrees farenheit) for 1,5 hours. Then turned off the oven and let the reamer stay inside cooling down with the oven. Tried the file again, but now it feelt too soft again...
Today I performed my third try, same coal forge but I believe I heated it up too much. For sure the reamer got warmer than last time. Quenching in the same canola oil. But this time it felt much softer when testing with the file... Could it get softer if heating too much (I would have guessed it should get more brittle)?
So here I stand
Sorry for a very long introduction. I would really appreciate some tips or guesses for what to do next. Have I destroyed this part or is it possible to perform several heating/quenching operations on the same part? I really want to avoid making a new reamer (an awful lot of time on my manual lathe). What are my best chances to succeed in the next try? Even though I'm fairly sure I heated it up too much this time, I didn't feel any brittleness. If I try to heat it up again, with a magnetic test more often trying to be more correct in temperature - should I go the with the canola oil again or do you think I should try with water instead? All input and tips are greatly appreciated
So here I stand
