- Jul 21, 2001
The Titanic was one of the most publicized incidents of steel failing in cold temperatures it was not designed to experience. One question that may be extremely relevant if you are planning on survival in cold temperatures is: What is the temperature range these blades are suited for?
Knives tested for edge flex and strength at moderate temperatures in our shops can fail in sub-zero temperatures. It is easy to test and adjust the tempering temperature to allow for extreme low temps, but the variable needs to be in your plan.
A blade that is tempered for use at low temps will loose a little edge holding at moderate temperates, but this little cost in edge holding is more than worth it when cold weather use may be in its future.
Knife users can test their own blades by simply putting them in their house hold freezer and testing for edge flex while the blade is still cold. Winter time is the best time to test as you can test outside, cold steel on cold steel.
You can make the test simple by chipping ice, this test can be very revealing.
Your thoughs?
Your thoughs?
