This Titan Defender Lightweight, first off, is no light weight - it is slightly heavier, in the hand, than the same sized Titan Worker. It seems to have suffered from assembly problems. Unlike the Haddock, it did not get the blade's lockbar surface bearing area polished then fitted to the lockbar in assembly. The high RMS roughness of the stonewash blade, similar to the Haddock's, results in a scratching opening of the lockbar when closing the blade. To polish it now would result in a loose lock, as it already has about 40% engagement. The blade surface roughness likely affects the pivot, too. I haven't disassembled it, so I don't really know. The Haddock has dissimilar bearing washers - and dissimilar sides. The TDL, like the Titan Worker, has similar sides - and dissimilar bearing washers (Unlike the Titan Worker - it's washers look identical - and it is quite smooth in operation and centered when closed!), the thinnest being on the non-lockbar side - the side that is 'too close'. A tad more thickness in that washer would likely center the blade - and prevent the one drag spot just prior to closing. Said drag spot occurs at the apex of the second finger groove - about mid blade - and leaves a little greyish Ti rub mark, which wipes off with a finger, at the blade's spine/beginning of the reduction interface. It is felt just before the lockbar ball drops into it's locked closed hole on the blade. Said closure was exceedingly rough yesterday - a night of soaking in reddish Gun Butter's 'Complete Firearm Lubricant', a sample bottle with the needle applicator having been given to me to 'try' on knives, etc, making it much better. The rough opening of the lockbar, from the aforementioned surface roughness, did not change.
For a $330 MSRP knife, this is an insult. I know what kind of quality, especially in the fitting department, $350 buys in an American knife - my recent Ti/S35VN CRK small Sebenza, sitting next to the TDL now - is testimony to that. I also know how well fitted and uniform/sharp a Buck 110, at <$30 from WallyWorld up the street, is - it can be done. In the middle, say $200+, we have great examples of American made knives, my recent ZT-0551 coming to mind there. Selling sub-production quality knives at custom knife plus prices just isn't right. Maybe the problem is in QC inspection... maybe they just need mandatory periodic vision tests for final assembly and QC inspectors! Seriously, how could you put such a poorly assembled knife in such a nice box? Of course, my trio of Chris Reeve knifes came in rather plain white cardboard boxes...
My bitterness stems from the disappointment over several expensive Bokers over the last few years: Titan Worker, Haddock, Savannah, and the Titan Defender Lightweight. Firstly, the Micarta looked flat on all of them - sullen, even. A small amount of light clock/gun oil darkened and brought out some color - still not what one views in their ad copy. The blade on the Savannah was much thinner than advertised. The operation of the folders, except for the Titan Worker, was sub par. Only the TDL came sharp. This follows my glee over rediscovering the finely executed and highly functional Boker Tree Brand classic slipjoints - which have forever spoiled me for the likes of Case knives! Every blade on all of my Boker slipjoints came sharp, too. It seems it's feast or famine with Boker.
Stainz
