- Feb 24, 2000
I quenched a 26c3 blade and it had a warp. There are several ways to deal with warps but the best way I had found so far was to temper the blade once for two hours, let cool then start tempering the blade again. After the blade gets up to the temper temperature I would take it out put it between a jig with two bars on one side and one bar on the other, put it in a vice and over correct the warp. That usually worked.
Well, on this last blade I tried several times to correct the warp and it wasn't happening. So I really cranked down on the vice and the blade warped the other way. So I put it back in the Paragon let it get back to the temper temperature, (400 degrees) took the blade out, placed it on the anvil and used a ball peen hammer to straighten. I was tired of fooling with this blade and if it broke I really didn't care. It worked like a charm.
I have only done this once. Has anyone else ever tried this?
