Earlier this year myself and three of my friends started a project for my college (WPI) involving the historical evolution of materials used in arms and armor through the middle ages. We decided to research Japan during this time period, focusing on the Samurai. For this project, we have two deliverables: a rather long paper, and a katana. We found a blacksmith in the area that is helping us make the sword, but we have been running into problems and would like some advice. The idea is to stick as close to traditional methods without going overboard.
The original idea was to use a high carbon steel as a single layer, work it into shape, and use layers of clay on the metal to control the cooling during quench to create the hamon. For this we selected 5160 steel as it seemed to be the one that most accurately mirrored the carbon content of the steel used in Japan during the Samurai. We changed this idea after we got the 5160, and decided that we want to actually make the effort of inserting a rod of low carbon steel inside the 5160...again to keep traditional. This is where we began running into problems. Through experimentation, our blacksmith and I found that we could not get the 5160 to adequately weld to itself. The most we got was 3 small spots of welding...and that was after we heated it to bright yellow and used a vice clamp to squeeze it into a weld. This was after we had met with failure the previous two times we had tried to weld 5160 to 5160 with hammering. We have a rod of low carbon steel that is ready for use, but my question is the following. Is there a way to make the 5160 work in this regard, or would we better served in going with 1075 or higher?
Thanks
Thanks
