Any chemists in the house?
Spark
HPIC - Hatas gonna Hate
Staff member
Administrator
Super Mod
Moderator
My wife is trying to make a solution of water & l-ascorbic acid (however you spell it). The solution has to have a pH of less than 3.0 or else the l-ascorbic acid apparently will not absorb and will break down. It needs to be a minimum of 15%-max 20% in the water. She's down with ferulic acid or vitamin e for stabilization. She just can't figure out how to get the l-ascorbic acid to dissolve correctly.
Currently she's been trying distilled water, but this isn't working.
This is for some sort of skin care regimen, but I don't understand her witchdoctor stuff.
Any chemists or chemistry majors who can help me out?
Riiiight...admit it, BF ain't making enough, so you're starting a meth lab.
It's a hell of a drug.
Arrrgh Capn, Sar. Reportin' for duty, Sar.
According to an MSDS I just checked, ascorbic acid is water soluble up to 33 grams per 100 grams of water. Making the initial solution should be a matter of dissolving 15 grams of the powder in 85 grams of water to get a 15% solution. I'm afraid it's been too many years and I can no longer calculate the pH. But you should be able to buy pH paper at a pharmacy and just measure it. If not, most good-sized cities have chemical supply houses that will sell over the counter. pH paper is inexpensive. They make different papers that measure different ranges. Make sure you tell the fella behind the counter what pH you need to measure.
Once you measure the pH, if the solution is too acidic (pH is too low) then you can bring it back up with a bit of Tums. If the pH is too high, you can add a drop or so of vinegar. If you want a bigger batch (100 gram is a pretty small volume) you can bulk up the formula by multiplying the amounts.
Neither vitamin E nor ferulic acid is water soluble. So if you combine either of them with the solution, you will only get an oil in water gloppy mix (you should pardon the technical language) like Good Seasons Salad Dressing. I'm not sure what she wants to do with those. Perhaps she wants to make a hand cream? She might be able to make an emulsion. Most hand creams are emulsions. Ferulic acid should make a reasonably stable emulsion without the need for further emulsification agents, though this is just an educated guess about not needing further emulsifiers.
If she wants to make an emulsion or hand cream type of deal, that may be possible in the kitchen. In order to get an emulsion, you need shear. Lots of shear. You should be able to use a kitchen blender to do that.
There are two types of emulsions. Oil in Water (drops of oil in water), and, Water in Oil (drops of water in oil). For a hand cream I think you can use an oil in water emulsion. I've made those in the lab, but it was about 15 years ago.
Start with the oil. Put enough in the blender so as to be maybe an inch or two above the blade. Turn on the blender with it set on low or medium. Add the acid solution slowly in small increments, almost drop-wise. The blend will get thicker and as you get more acid solution in, it will turn white. As you add the acid solution, it will get thicker and thicker. Then all at once, it will drop in viscosity. That marks the point where you now have drops of oil in water instead of drops of water in oil. The technical term for it is "inversion".
Once the emulsion inverts, adding more water will cause it to get thin. Probably not what she wants. If it were I, I think I would stop as soon as the emulsion inverts. It should be reasonably stable using those oils, but you may need a stabilizer to keep it as an emulsion for a long time. What I'm try to say here is that there is a tendency for the droplets to recombine and become just oil mixed with water, which is probably the gloppy stuff she has now.
If I have guessed wrong as to her intentions, my apologies. Feel free to drop me an email and I'll see if I can do better.
Arrgh!
Just a wee bit of heat perhaps.
l-ascorbic is only partially soluble in cold water and is more soluble in hot water. Solubility in water: 80% @ 212 deg. F and 45% @ 113 deg. F. A 15 - 20% solution should put you slightly above body temp.
Grab your bunsen, beakers, and Mrs. Spark and have fun!
j
none of the instructions I'm finding say anything about pH.
I suspect the pH of 3 comes from having a 10-20% solution.
all of the instructions I found talked about a 1 week shelf life once the stuff is mixed.
easiest set of instructions I found are these:
Vitamin C Serum (10%)
Ingredients:
½ teaspoon l-ascorbic acid powder
3½ teaspoon distilled water (bottled water is fine, should be at room temperature)
1½ teaspoon propylene glycol or vegetable glycerin
1 amber or dark blue glass bottle
Instructions:
1) Make sure your glass bottle is sterile by boiling it in some hot water. You can also sterilize it with some rubbing alcohol.
2) Wait for the bottle to cool and dry completely.
3) Add the l-ascorbic acid to the bottle.
4) Add the distilled water.
5) Swish around the bottle or use a stirrer until all the l-ascorbic acid is dissolved.
6) Add the propylene glycol or glycerin (must be vegetable glycerin, however you can use Monistat Anti-Chafing gel if your skin is fine with silicones)
7) Mix well (cap the bottle and keep shaking until everything is blended or use a stirrer) and use up as early as possible.
Comments:
You want to use a dark bottle because it prevents the l-ascorbic powder from oxidizing. L-ascorbic powder is destabilized when it reacts with light and/or heat, so store your homemade C serum in a cool, dark place.
Mix well and use up the C serum as early as possible because l-ascorbic acid is highly unstable. Make a new batch every few days because as time goes on, the l-ascorbic acid grows less potent.
You can also make this serum with just water. However, without the propylene glycol or glycerin content, it will oxidize very quickly. If you make it with just water, you have to make a new batch every day.
Make sure the l-ascorbic acid you buy is 100% with no additional ingredients. You can buy powder or crystals (from the vitamin section in your local health food store), but I like to use powder because it dissolves faster. Sometimes Vitamin C will just list "ascorbic acid" as its ingredient. If this is the case, call the company to see whether or not it's l-ascorbic acid. Also, make sure there are no unnecessary ingredients in the Vitamin C capsules you buy (such as sweeteners, rose hip oils, etc).
If you find this percentage of vitamin C to be too irritating, you can always add less l-ascorbic acid. If it's not strong enough, you can add more, but don't go over 20%.
Both propylene glycol and glycerin will mix with water. No emulsion necessary.
If your wife is good with using those ingredients, 1066vik's formula would be easier to make.
I agree that a 15% ascorbic acid solution should be doable in room temp water.
My wife says thank you for the tips!
