- Jan 27, 2008
I have a basement reno question?
I have removed a 60-year old cold closet/root cellar from my basement that was directly below an entry stairwell into the main house above. I also poured a concrete to patch over cover the old gravel flooring that was inside. I now want to remove the final, small weight bearing wall below the landing. I've tripled up the support in the meantime. Can I use metal strapping tied into the floor joist above to adequately/securely suspend the structure's weight, and allow the removal of that wall?
Do I need to double-up the joist in question?
Should double-up and re-design the staircase riser to also provide "some" support to the landing? Its certainly providing little support in its current configuration.
Thanks for the help,
-Peter
-Peter
