Any drummers here?
So I just started drumming, but I still need to get some drums, cause right now I'm just using a Yamaha DD-6 from my friends basement. So I was wondering if y'all had any recommendations for a first drum set? I'm looking to spend about $250-$300, but I might be able to stretch that a bit further. Also, what sticks/stool, would y'all recommend? Thanks for the help.
KB3UBW
Can't make too many recommendations since I've been out of the fold for a few years. I have Tama Superstar drums and they still seem competitive. Back in the day, they were regarded fairly well. Billy Cobham was one of the early high visibility players. Vic Firth were always the best feeling sticks of the bunch compared to proMark and Regal Tip. As far as drums to buy, it might be touigh to do it on your budget esp when you consider cymbals. There are lots of entry level setups available so just do some research and pick the brain of the guys at Sam Ash. also look out for craigslist stuff as people buy lots of stuff only to get rid of it after a few years time and drums last a long time if not abused. There should be good deals on higher quality used drums out there.
Thats a very low starting point, I'd say save for a bit longer and start with a pearl vision kit, You can find them used for between 500-900 dollars. The good thing is you will get a good re-sale value and Pearl has a life time warranty on all there stuff! check it out. As for sticks, Vater are decent but start with some some cheap ones and buy 3 or 4 sets of them cause you will break them haha. After you learn some stuff and figure out your sound you can pick a specific tip for sound, Tear drop, Acorn, Barrel they all produce different sounds.
If you cant find a decent Pearl Kit, Go for Yamaha
I'm not a drummer, but I've lived with a couple, and I've set up and miced a few kits. As far as priorities go on getting gear, you want to have a great throne. Spend the money you need to to get the seat that fits you. Next is the snare, again, find one you like, but there has to me a reason why most of the backline I've set up has a note "drummer providing x size snare, provide stand to fit" Finally, you'll end up finding petals that work for you. Try as many as you can. Mixing and matching is your friend on a budget, and if you can find yourself a drum frame, it allows you much more freedom for what you end up with. (although some guys really love having everything stuck to the kick) And don't waste money on a double kick unless you really need one.
Since lots of drummers change out gear, finding used bits and pieces should be easy, but don't be afraid to turn someone down if it doesn't sound right to you. just like buying cars, if you can't drive it, don't buy it. Don't let someone sell you anything you are unsure of.
The only thing I've heard about buying sticks, is to buy a pair whenever you can, so that you don't end up with several sets from the same batch in case they are brittle. (although I've also been told by much older drummers, that if you are breaking things, your technique is bad)
So, two things, I've decided to go with a electric kit, so I can practice without waking up the house, and I've upped my budget to 500-750, although I could go a tad higher if I needed too. Do y'all have any suggestions in that price range?
Yamaha DTX500 or if you fork out the extra 50 go with a Roland TD4S V-Compact Electronic Drum Set, The Roland is the best bang for your buck! Hope this helps
I looked at those, and I'm liking the roland, I even found a couple lightly used ones that fit my budget. Thanks!
I think the rolands have the best support as far as adding new pieces, but I'm not 100% sure on that. What I do know is that finding a kit that can be customized down the road is the best plan, even if all you start out with is a couple simple MIDI pads. And to be honest, high end pads can be used to the same effect as real drums, enough so that more than a few folks prefer to record that way as it is much easier to get a clean recording, room acoustics can be a bitch when trying to record a drum kit.
