- Mar 19, 2022
Found this in an antique shop recently. I love the bevels. Any info on its age or rarity? It's hard to find info on these.
Thanks!
Thanks!
Unfortunately the handle is really warped. I'm going to take it off and fix it up/try to bend it back into shape.Michigan pattern, my guess is 1950's for the age.
It looks to be in great shape without much wear at all.
They don't seem to be all that common to me, but I'm not exactly in the game like others are.
You got a great axe there, a wire wheel to remove the rust ,a file to get the bit cutting again, and some care to the handle and it'll be good to go I bet.
How does the handle look ?
Good luck.Unfortunately the handle is really warped. I'm going to take it off and fix it up/try to bend it back into shape.
Boiling water is the safest and best way I think.Good luck.
I've had sucess , but theres no guarantee.
My method was clamping it to a board with a spacer so I could get some bend in the other direction, then using steam from a pot of boiling water.
But it's the heat not the wet that allows the wood to be bent. This is why I wrap my hafts with kitchen plastic wrap before steaming them. And recall that indigenous arrow makers work with dry heat to straighten an arrow shaft, either over a grooved stone or with a bone wrench with a hole bored in it.oiling water is the safest and best way I think.
I have had no luck at all without heat. The hafts just go back to being how they were before and usually sooner than later.
Yes, it's the heat. I have heard of using grease for the same purpose you are using the plastic wrap. I think either way steam or dry heat dries the wood and increases the risk of breaking, so it's not a bad idea to protect it.But it's the heat not the wet that allows the wood to be bent. This is why I wrap my hafts with kitchen plastic wrap before steaming them. And recall that indigenous arrow makers work with dry heat to straighten an arrow shaft, either over a grooved stone or with a bone wrench with a hole bored in it.
Arrow Shaft Wrench from the Thompson Site, 14RC9 - Kansas Memory - Kansas Historical Society
Kansas Historical Societywww.kshs.org
Syringa and red osier dog wood are pretty good too.If I were to make arrows I'd use meadowsweet/oceanspray or service berry, both plentiful here.
