Hello,
I'm trying to get started in knife making and have been making plans and designs for about a year. I finally saved enough to get myself a 2x72 belt grinder and all my belts and also pulled the trigger on some steel. Given how expensive the grinder and belts were, I started small with just a single 3/16" by 2" by 36" bar of Cru-wear from NJSB.
I was always planning on using 3v, but they had none in stock, so I wanted to make do and make sure everything would be arriving at once to minimize downtime and just get started next weekend when everything would be here.
I'm kind of stressing now. I have been planning out my designs and I always kind of wanted my flagship to be a 12" OAL bowie with a 7" blade. Kind of a traditional mk2 combat knife with a full tang and walnut scales and brass pins. But I was thinking about it and realized as I've been planning this out and researching knife designs and what's out there, I've never seen a cru-wear knife with a longer than 5" blade.
I'm a graduate mechanical engineer, so I'm familiar with the technical aspects of the metallurgy and I have Larrin Thomas' book and am aware of the toughness difference between cru-wear and 3v, so I was wondering if anyone had any experience either making or owning a larger cru-wear knife. Is there a common knowledge of the size limitation of cru-wear when the lateral stresses start to be too much if you're wrenching on a 7" blade that I wouldn't know about?
Looking at the charts for Toughness-Hardness I know at its highest Cru-Wear can manage 20 ft-lbs whereas CPM-3V its at minimum 30+, but CPM Magnacut is at its highest at around 15 ft-lbs and Architect Knives recently put out a model with an 8" blade in Magnacut.
I have other designs ranging in length, the smallest being 9" OAL with a 4.5" spear tip. So, I could make 4 of those instead of 3 of my larger design.
I may be just overstressing but I would appreciate any input.
Thanks for taking the time to read this,
Keith Larson
Keith Larson
