I feel that you are going to have lint problems with just about any lube but you can reduce the amount of attraction by using some different types. I've used the CRK stuff, CLP and Militec-1. Militec-1 that has been heated with a hairdryer seems to work the best. Less lint and dirt. It seems that it is cleaner of the three. CRK cleans up fine but the CLP needs some extra soap/degreaser and brush to get all the left over residue. And to top it all of Militec-1 seems to be a little smoother when dry; I find this true only if you lube all metal to metal contact points and dry it. For example, the Sebenza CRK breakdown instructions informs you to not put lube between washer and Ti handle. Well, let me tell ya if you don't you are not going to have a smooth action. Metal to metal contact needs lube. If the idea is that the Ti handle has enough grip to stop the washer from rotating then they are out of their mind. Lube is too stuff, the machining is good stuff but dirt, lint and whatever else just gets in the way. Plus, metal on metal rubbing is just not good.
