Any opinions of EdgePro Sharpener?
Who has used one, and is it easy to learn. I saw mention of one in a knife review, and checked out their website. I like the idea that you don't clamp your blade. I've never had much luck with the clamp models. Much better results have been achieved using a DMT rod or stone freehand, but I'm looking for consistent repeatable results in less time. Looks like this is a good option, however pricey. Please give your thoughts.
Mike
I've had one for about 3 weeks now, it takes a little getting used to.
As you've said, you don't clamp the blade, you kinda have to float it across the platten/base, as you stroke the stones against the edge.
Long slow strokes are always better/more effective:D . Always keep the edge of part you're sharpening parallel to the edge of the base,(you'll understand when you use it)
It'll reproduce any angle, and once you reprofile all your blades, you don't even have to remember what angle you used, just use a sharpie to mark your edge, than adjust the angle till the marker comes off. Lock the angle and a few swipes with fine grit and your ready to slice. You can also use the steel,(additional $15 cost) to bring your edges back up.
This thing really shines on kitichen cutlery and bigger chef's knives. Smaller blades take a little more practice, but it does a great job on all, including chisel ground tantos.
To sum it up, it's well worth the money, it can do what Ben says it will, and been is a great guy to deal with, makes a great product, and takes great care of his customers. (Ben do I get a discount on my Professional when I'm ready to upgrade?;) .
Hi Medic :)...yeah the Edge-Pro is a turly good jig set-up! I have used the Pro-Model off and on, and although I prefer using Norton India Tri-Stones.., the Edge-Pro is very fast once you get used to it.., and as mentioned.., very consistent.
It is pricey.., but far and away better than anything similar in my opinion.
"Hunters seek what they [WANT].., Seekers hunt what they [NEED]"
Top quality, expensive-but worth it. I don't use it as much as I thought I would because of the set up time, but glad I have it. Ben is good to deal with, knowledgable, sells a top notch product.
If you like your knives ridiculously sharp, and have the $, get one.
I've reprofiled all my edges with it to unbelievable sharpness.
But once I've done this I find I can keep everything hair poppin sharp with my Spyderco Sharpmaker. So I really only need the Edge-Pro once per edge. I assume I'll need it eventually again after much use of my blades.
Only negative is that you have to protect the sides of your blades if you care about scratching.
Where the knife sits on the Edge-Pro is where all the abrasive slurry collects. Gotta tape the side of the blade and rinse the area off frequently. Other than that, it's a wonderful system.
Lenny
I highly recommend it. I never had much luck with other sharpening systems, but get *great* results from the EdgePro. It takes a few knives to learn with, but it's easy overall. The third knife I did came out sharper than anything I had ever done before. It is a bit more expensive than other systems, but it's worth every cent.
I agree with everything said above. I've had a Pro model for 2-3 years and I wouldn't do without it.
As for learning to use it, like any sharpening tool/technique, it will take some practice. Ask around your family and freinds or visit some garage sales and find some cheap knives to start out on. Once you get the feel for it, you'll be able to put a fantasic edge on anything.
One last thing, Ben Dale is a great guy to do business with. He's happy to answer questions and help you learn how to use the EP.
Brent...
:p
