- Mar 7, 2000
if so, show 'em if you got 'em
Originally posted by slag
harrydog,
don't worry about lockup. My flat ground GB locks up the same as the flat ground AR in the pics. Everything is solid, and may break in over time.
As for the o-ring. I read your post, then checked out the pics. How ingenius, I thought. So I went to the hardware store and found one that did the trick. I believe it was 1/16"(cross-section size) x 3/32"(circle diameter). It was quite a stretch, and therefore won't be coming off in the pocket, in drawing, or in use. It does the trick too. No more ouchy thumb! The little bastard did set be back $.42 though....![]()
These strider folders are definitely the sh!t. Cause sometimes you need more than just something to cut with, these folders offer that piece of mind.
Oh, and no reprocussions as of yet, from removing the two-sided washer goo (I think you replied to my post on that). That's been with several openings/closings, twistings and flickings. She is definitely smooth for any knife, which is even more amazing when considering the colossal size of these things!!
