- Oct 20, 2004
I have been having an on going problem with one of the septic tanks/ drain fields in the house. I was wondering if there was a plumber around or someone familiar with a septic system?
It has been backing up and at first I thought it was a clog but now I think it is a problem with the tank or drain field.
The tank outlet and inlet are both at about the same level and at the top of the tank. This seems strange to me as then there is no room in the tank for water to accumulate and then slowly make it's way out to the drain field and absorb into the ground. I would have thought the exit would be like a foot lower than the entry so that you have some 'working room?' Is this not the case?
How often should a tank be pumped?
I had a problem with the drain field about a year and a half ago. At that time when I dug down to the drain field water would come rushing out because I guess a hard pan is forming that is not letting the water seep into the ground. I expanded the drain field some and had the tank pumped and it has been working fine.
Now when I dig down to the drain field I do not get any water so it seems that the drain field is working or is clogged somewhere between the tank and drain field?
The tank seems like it is full and that it is backing up into the house because it has no where to go. I pulled the plug outside between the house and tank and ran the shower and water seems to be coming out ok so to me that rules out a clog.
If anyone is familiar with this stuff do you have any thoughts or suggestions? I guess I'm about to drop the $350 to have the tank pumped but that doesn't seem to me like it is fixing the problem when it was pumped about 15 months ago. I'm thinking about renting a tractor and doubling the size of the drain field because there is lots of clay and limerock in the ground and it seems to be forming a layer. It's weird how quick a layer of clay can form out of nowhere (at least that is what it seems like) so quickly because when digging down where it was dug up before I am already encountering a clay layer.
Anyways I am just trying to get some insight. I'm sure if I paid someone they would just say I need a new tank and drain field and that it is going to cost 15K. I can do the work myself I just need to figure out what the problem is.
Thanks!
Thanks!
