- Feb 5, 2013
I've made one small knife and started another using the ball peen hammer I already had, put second on hold until the cross peen hammer arrives. In both cases I've had real trouble getting the tang to ricasso transition right. Basically, starting from the rear of the tang and looking down from the top the tang gets wider until the point where the transition starts. Then it gets thinner before the ricasso is fully there. This means a guard or bolster that slips over the tang and abuts the ricasso has spaces on the side. I've relied on using a file to finish defining the full sharp transition to the ricasso (w/ very small curve instead of true abrupt 90* angle). I think my problem is from not forging the transition itself much more fully. I got around the problem with the knife I finished (tung oil drying now) by cutting the handle in two and carving out a slot on each side that the tang fits very tightly in. At least I know there is really no way for it to pull out once I glued it!
I'm having trouble understanding how to move the metal here. I tried the modelling clay suggestion but the clay I have doesn't work for this when turned on edge - it is great for getting a feel for how the metal will move, curve etc. when hammering the bevels though. I'll ask about clays with stronger structure at the great ceramics art store where I got the bricks for my forge.
Anyone have suggestions or know of a video showing this being done? I've tried working on the edge of the anvil approximation I have (It's not even an ASO... back flat space of cast playdough bench vise - also waiting for the sledgehammer head to arrive to make a post anvil that I don't worry about breaking with every hit). That's probably part of my problem there: I've been hesitant to hit all that hard and have been using a 10oz or something ball peen.
This is with 3/16" 1084 bar stock, thicker by far than the blades I've worked on but just right for the other things I'm making from it. I'm forging instead of stock removal because it is much more fun for me. I still ended up doing more stock removal than I would have if I knew what I was doing.
Thank you!
Thank you!
