Any suggestions on Western Bowie
PCL
I have an older Western bowie pre-49 that I have had for years. This is the condition I found it in and I have often thought of having tang repaired and then re-handle it. I believe the sheath is also period correct but obviously in bad shape. I'm not a welder so I can't fix it. Leave it alone or fix it. I know the option is mine, just wondering would you all might do, I can afford to re-furbish it, but would anyone else bother?
Sure looks like a W49, except for the short tang. How short is it? Maybe there's enough.
As long as the blade and remaining tang is intact, there shouldn't be much trouble making a new handle & guard.
The tang can be lenghtened without welding, with a bicycle chainlink and a 1/4" schackle screw.
Then You can make the handle You want and get it tight with a pommelnut.
Like this!
Regards
Mikael
Now that is nifty thanks, but I want to return it to original specs but in all the threads and other places I don't think anyone ever determined what type of steel they used. I want the full tang back with brass guard and rosewood handles.
Well, then You will have to forge a new tang to the old one.
I guess it's not worth the expence, unless You are skilled in forging and can do it Yourself.
J. Neilson M.S. do handforged bowieblanks for homebuilders.
I guess I would go that route before spending $$$ on a reforge.
Regards
Mikael
The blade should be made out of high carbon steel. I think 1095. I do have a W49 but it is a 1987 model. Here are some knife specs I found • Blade Length: 8.875"
• Handle Length: 6" • Overall Length: 14.875". Mine is a full tang design and from the front of the hand guard to the end of the handle is 5 1/4 inches so I believe that the tang has been cut off. If you want some pictures let me know.
I've seen a couple certificates of analysis from Western during the '65-'77 period. The high-carbon (i.e., non-stainless) steel was 1095.
Actually most of the catalogs are mine. It is hard enough finding info on Western so I wanted to share what I had.
