Any thoughts on a tough folder with 5 inch blade
Check out some of the Cold Steel offerings - they tend to go big along with strong more than other MFG's. 5" blades on folders are not too common. Cold Steel offers a few in that category or close to it.
The Spartan is 4.5"
The Espada Series is 3.5, 5.5 and 7.5"
The Rajah II is 6"
http://www.coldsteel.com/folding-knives.html
The Spartan is 4.5"
The Rajah II is 6"
Yup, Cold Steel was the first mfg. I thought of reading the OP.
Megafolders used to be a regular item but now smaller hard-use seems to be the norm.
Too bad Camillus isn't around to make more CUDA Maxxes. If you're OK with the cost, Darryl Ralph has a forum here now at HTM Knives. Check out Extrema Ratio for another expensive brand.
Cold Steel, of course, including their Voyager and Vaquero series. SOG has a couple of 5" folders, the Pentagon Elite II and Spec-Elite II.
Thanks for the input guys and yes Esav, cost does have to be part of it. Maybe $200 max. I would be ecstatic with a Darrel Ralph. :D
A rajah 2 might fit the bill with a little modification.
I have a CS Gunsite with a 5" blade, but they don't make those anymore.
I have an informal "set" -- the Gunsite II and a 5" Voyager to with it. They look good together. :)
Grayman just came ot with a MASSIVE folder, the Satu, looks reeeaaaaalllly tough. Limited run though, I don't know if they're still available.
Not bad looking, not really massive actually. A bit expensive. Probably a good piece of equipment. I do like the design.
According to the website, still available.
Yeah, not really massive. A lot bigger folder than I'm use to though, so kinda massive for me.
Though not quite 5.0" blade, actually 4 5/8", the Ontario Hossom Retribution I is a very tough folder. Built like a brick sh*thouse with thick titanium liners (.100" thick), and a thicker blade at .200". Course it is a sheath carry only folder......unless you have the desire to turn it into a pocket clip folder, cause it is possible.:)
Just a stock photo.
[/IMG]
