CS tomahawks in the Peter LaGana format are best sharpened for use in the following manner.
Contact a knifemaker or a professional sharpening service and ask him or her to do the work for you.
I've had 3 CS VN style tomahawks professionally sharpened by knife maker Bill Buchman. They were returned with an exceptional working edge on all those surfaces that require being sharpened per Mr. LaGana.
These include the primary cutting/chopping edge, the bottom edge (for hooking / slicing), and those edges on the spike portion of the tomahawk head (4 in all).
Having purchased one of the numbered LaGana Tomahawks from BQ recently I discovered it, too, required additional sharpening of all those edges noted above. I had this 'hawk professionally sharpened by knifemaker Woody Woodcock. In this instance the spike was acceptable given its intended design use to puncture light headwear and skull bone. The primary and bottom edges of the 'hawk needed to be brought up to snuff and this took about 20 minutes for Mr. Woodcock to accomplish.
Because the head is affixed to the handle in the manner it is, the handle was marred during the sharpening / buffing process. This cosmetic issue was squared away by 5 minutes of staining and hand rubbing. Clearly if one is buying such a piece for its collector value then leaving it intact as sent from the vendor is necessary.
I've owned an original VN Tomahawk (pristine condition) and noted it would have required final sharpening by its owner upon purchase, as well. I've also enjoyed the opportunity to have interviewed Mr. LaGana formally, and have both his throwing and VN Tomahawk manuals as published during the heyday of the American Tomahawk Company in the 60s.
Sheathwise the CS leather sheath is acceptable if you weatherproof it as you would a pair of leather hiking boots. The Eagle sheath that comes with the numbered model from BQ is sturdy to beat the band. It is also near impossible to draw the 'hawk from swiftly, and is a bear to replace the 'hawk in afterward if you've mounted it on your belt or combat harness / rucksack.
I just saw where Jeff Loffer of Cutlery Shoppe is offering both a kydex-style belt sheath and / or shoulder harness for the VN 'hawks. This is the way to go for those who are planning to carry this piece of "cold weapon" into the combat environment. The multiple sharpened edges require the best possible user protection during storage and carry, as well as during the draw stroke and replacement into the sheath. I believe Loffer has this covered with his kydex-style sheathwork.
Training 'hawks used to be available from Jim Keating at COMTECH (VN 'hawk model). Sadly, I don't know that Mr. Keating offers this wonderful training tool any longer. Initial schooling in the use of the VN 'hawk first began at Keating's Riddle of Steel on the Snake River. Jim once did a video (as I best recall) on tomahawk work and this may still be available from him at COMTECH.
It would be wonderful if Mr. LaGana would consider re-releasing his "how-to" handbook on the VN Tomahawk. This is a handy little guide for this specific 'hawk and from the man who designed it and made it happen. I particularly enjoyed learning how to fully use the entire design matrix of the VN 'hawk, to include handle strikes / hooking / choking / and slapping. The handle itself is designed for swift reversal of the head so one can (for example) hook, drag, reverse, then strike with the spike. Using the 'hawk to parry incoming strikes from different weapons systems (knife, empty hand, rifle, rifle with bayonet, machete, opposing 'hawk) is likewise possible and was taught by Mr. LaGana.
Overall this is a fine weapon with as much practical application today as when it first was made available in the 60s to our forces in VN. I'm delighted to see Peter once again in control of his design and offering high quality product to those who value its worth as either a collector piece or working tool.
I trust the above is helpful to those of you looking for such information.
