Anybody know of a flashlight like this?
If this was a 2xCR123A model, it'd be exactly what I want. Problem is the real 2-cell version has a flared head and a crenelated bezel, which I don't want. It must carry bezel-down, and I'd like a Cree emitter.
Anybody know of such a light? BTW, I already have a D20. It's OK but not great and it's longer and fatter than I wanted, so 2AA models are out. Thanks!
Olight M20 Warrier R2.
Stainless strike bezel is removable, along with cigar hold ring. Bezel down carry. Longest runtime, and brightest light in its class. (3.5 days at 7 lumens, and about a week using an 18650 rechargable, 250 lumen high).
Oh wait, it's probably on the bulky side for your needs. Nevermind.
How do you like that D20 by the way?
If you are willing to accept a USA-made light which employs a K2 TFFC LED instead of a Cree, consider the 2008 Inova T1-MP. It emits a constant 100 lumen wall of light for 4 hours when powered by a pair of CR123A batteries.
It is better at producing a lot of spill rather than being a long distance thrower.
I've had the past 3 versions (2006 - 2008) of this light and they are built like tanks.
Here is a photo of a 2007 model which looks identical to the new 2008 100 lumen version. I use the 2008 version to walk nightly on dark rural roads and it runs cool during those prolonged periods of use.
Surefire E1B backup. Smooth everywhere, 80 lumens, 1 CR123 battery. :thumbup:
Wow--thought this wouldn't draw any replies. Thanks to all. What I see from the choices:
Landry, the P3D looks ideal in almost every respect. From what I see on CPF there are 2 clips I can adapt so I think this is the winner!
Parnass, the T1 really needed a clip. As long as it's got good output it doesn't have to be a Cree, but belt sheaths won't work.
Josh, 1-cells are harder for me to manipulate. If they made an E2B I'd be all over it.
K&G: I didn't know about that Olight. Neat idea! I had an Olight that was similar, but it went back to the seller because it wouldn't hold a light level. It always cycled through each of the 3 levels every time I turned it on.
To answer your question, the Nitecore D20's main problem is the battery drain. I went to use it a few weeks after I got it (I keep it set on highest) and it was dim. I hadn't run it more than a few minutes since I got it. I turned it off and found it was still on, almost in a "find me" mode, just enough to light the bezel. I unscrewed the bezel, put in new batteries, and turned it into a momentary-only.
The upcoming Surefire LX2 or A2L will do what you want. It will also have an E1B style clip, but longer. No word on when it hits shelves.
At 25 bucks, this one seems to fit the bill and has some nice specs: 220lumen/3+ hours.
http://www.shiningbeam.com/servlet/the-103/X2T-Tactical-Cree-Q5/Detail
Personally, I like single cell lithium lights. Less of a potential hazard. I'm partial to the 18650 cells. I have the first and second editions of the L-Mini. Great little light. Extremely bright and a solid hour and a half runtime on high for my older one. Just got the newer edition today and haven't played with it yet. Version 2 has even better specs and regulation. The first one is going strong after a year of hard everyday use on the job.
http://www.shiningbeam.com/servlet/the-42/mini-L-dsh-mini-1081/Detail
The guy that runs Shiningbeam is a class act and his MG line is first rate and reasonably priced.
Thanks for the suggestion. I'm not sure I understand your point about hazard, though.
It's important to make sure that all lithium batteries in a multiple battery light have a similar state of charge. If a dead cell is used with fully charged cells, there's a possibility of those cells or cell rapidly discharging into the dead cell. There's a lot of energy in lithium batteries and a rapid discharge generates a lot of heat.
Last night I threw two CR123A's in a Cree MC-E light that usually has a single 18650 in it, so it doesn't worry me all that much but it something to keep in mind.
I see now. Not a problem--I'd use primaries for this.
It doesn't matter. Fresh primary at 3 volts with a dud=same problem. Like I said, it wouldn't stop me from using or buying a particular flashlight. Mishaps are few and far between but it's something to keep in mind. Personally I like lights that take both type batteries. It's nice to have a light that you can throw some readily available primaries into when recharging is not an option. Economically it's nice to get a years worth of battery use for under 20 dollars with two 18650's. My photon requirements easily would have cost me a couple hundred dollars on primaries.
ok, for throwers: 2xCR123
here
these two links should defintely help you find what you are looking for :thumbup:
for 1xcr123
here
It looks like you want a 2 x CR123 light with a body that is roughly the same diameter all the way down. I have a few options that might work for you:
The already mentioned Fenix PD30
Jetbeam Jet-III Pro ST BVC - This one would be my personal choice based on your specs. This light just screams quality, but it is relatively pricey unless you are including Surefire in your search.
iTP C10R or iTP C10T - Adjustable brightness, great heat dissipation, and the best ergonomics I have seen.
