will22 said:I'm not too good at holding an angle, thus the apeal of using systems like the lansky. How exactly does the Sharpmaker work? Is there some form of guide to help hold the correct angle? All my freehand sharpening attempts usually end in disaster. I can acheve great results with the lansky system but reprofiling takes forever. Also I've notices that the edge will be scary sharp but that actual look of the bevel will differ in finish. I don't see how this happens because the stones are always moved across the blade in the same direction and I make sure to make enough passes to acheve to finish of whatever grit stone I'm using. It's not that noticable with higher angle bevels with with say a 17 degree bevel it is plane as day. I just can't seem to get that perfect, uniform, factory edge.
will22 said:The other thing about the lanski is there is no comfortable way to hold it over long periods of sharpening. The edgepro looks good with the suction cup on the base although it would be much harder to sit in my recliner watching a movie while sharpening.
Does anyone know if the edgepro suffers from the same angle problem as the lansky?
