Car engines are basically a form of air pump. They suck in air, add fuel at an exact mix, burn it to produce power, and spit out the exhaust. If you want to burn more fuel, you need more oxygen, which means you need more air. Because you can only fit a certain amount of fuel into a certain amount of air at normal pressure, engineers have designed engines to highly compress the air. This allows more fuel to fit into the same amount of space without it "raining" out of the air.
Engineers intentionally restrict the amount of air let into and out of an engine so that it produces less power. This, when done properly, can result in lower emissions and better fuel economy. You can produce more horsepower for your car by removing a restrictive exhaust or intake, and replacing them with better flowing parts. But without forcing air into the intake (supercharger or turbo), or adding more oxygen artificially (NOS), there is a limit to how much air and fuel will fit into the cylinders of your car.
These "tornado" products are supposed to work by "swirling" the air. Check out
www.spiralmax.com . This "swirling" air is supposed to work like a supercharger.
This is nonsense. Air that is "swirling" has the same volume as air that is standing still, meaning it also contains the same amount of oxygen. Swirling the air at the intake restricts air flowing into the engine. Why? Because the air has to travel a further distance. You can prove this to yourself; run fifty feet down the street in a straight line. Now try running fifty feet down the street in a giant "S". Which was faster?
Adding something that restricts the amount of air flowing into your engine will not produce more power. It may result in lower emissions, improved gas milage, and power loss, but up to a certain point, so will a dirty air filter. It may also produce worse emissions and poorer gas milage.
There are systems that use swirling air to increase the efficiency of mixing air and fuel at the fuel injectors, such as Chevy's Vortec. But, they sure as heck aren't some cheesy part attached to the intake. They're the result of billions of dollars of R&D and engine design by literally thousands of engineers.
On a side note, I've also heard a few stories of these things falling apart and sending pieces of metal into the engine.
So, buyer beware.
-- Rob
