I have a new one here in Desert Tan, and I'm impressed.
The only changes I'd make to it would be adding additional cross grooves in the handles on the sides at the front & rear to allow for a more secure sideways hold in the hand.
Otherwise, it's a fairly solid knife, the 440C blade should resist corrosion & while it isn't built for a razor edge, it can be sharpened enough for the purpose it was designed for.
It also addresses most of the weaknesses of the original wartime ancestor.
The plastic handle is solid & weighted, and while 440C isn't an exotic steel with a miraculous ability for edge-holding, this is a fighting dagger, not a survival knife. As such, it won't be used repeatedly in building shelters, making fires, skinning critters, and so on. 440C is a known standard, and how fancy do you need to go in steel on a blade designed to kill one person at a time?
Understand the knife, and with the materials used and the quality of manufacture (very good), I believe it's worth the purchase price.
If this type appeals or meets a need, consider that prices will not go down, it's made by a company with a name and a rep, and pick it up now before you find later on that when you finally go looking for one, all the German-made blades will by then be made in China.
Denis
