Moved my mini-review from an earlier thread to this one and posted pictures per request.
After looking the 183 over there is both positive and negative points.
Positive:
- Beautiful shaped and balanced blade - perfect length for a woods knife.
- Blade is mildly stonewashed. Not anywhere near as much as a "Ritter" blade - it is hardly noticeable.
- Blade is really stout, and is sharp with an even edge-grind on both sides.
- The handle is G10 and nicely shaped (except for the negatives listed below).
- It could be used to dress and skin larger animals. For Deer using a forward hold with the thumb on the thick flattened spine it could actually work well for skinning. However, there is other knives that would work better.
Negative:
- The handles hump at the center-bottom is not comfortable when holding in some ways. It is most comfortable with a forward hold. I have average size hands (size 5 gloves).
- I would prefer the smooth G10 had a little more texture for an outdoor knife, but it is still OK.
- The Kydex Sheath has two square "mounds" that a regular belt passes through (one for regular height and the other for higher carry) but since they are hard they will probably dig into your hip/side making it uncomfortable. Also both "mounds" have a large opening that is covered by the belt, but the one not used will expose the blade to water/sweat/mud/dirt and are too high up on the sheath to allow water drainage. All the pictures I've seen of the sheath show the side without the "mounds" so it was a surprise to see them. Two Molle clips (short and long) is included.
So overall, I'd say Benchmade designed it as a tactical knife and I'm sure it is great for that purpose, but for those that want a little "cool" with their outdoor/camping knife it could also be used for either purpose.
Addendum: I experimented with the included "long" Molle clip and it can be threaded vertically through both plastic mounds so it forms a loop that will allow a larger belt to be used. It's still not a very good way, terrible actually to attach the sheath to a belt. I am leaning toward buying a kydex sheath for both my 183 and Bushcrafter from "Godspeed Tactical". To me the best sheath is Ballistic Nylon because the safety strap they use (like on a leather sheath) provides more confidence in retaining the knife. It seems like Kydex is taking over the sheath industry.
Edit: Reposted slightly larger pictures and to say that if you lay the 183 on top of the 810-1401 Contego they are virtually identical in shape and size except the 183 doesn't have the jimping on the bottom, the blade is .008-thousands thicker and has been extended at the rear one-inch.
