Hi Alex. The stuff is not as brittle as poly pearl or corian but does tend to grab a drill bit the same. It polishes well and without a close inspection (no cross hatching in the end grain) is a damn good copy. Use fresh belts as it can gaul a bit. The other give away is its temperature, real ivory is colder to the touch but that might just be me.
I am in no way suggesting you sell it as real ivory and it is probably best not to use it on higher end knives. I would imagine it has the same resale value as micarta. Hope some of this has helped.
I've used it in the past and liked it. It requires a soft touch on the buffer when finishing, as it can melt/streak in spots if hit too hard and heat builds. I used a loose wheel buff and white compound.
How does it hold up in use? I have a set of scales I bought, from where I can't remember. It looks good but feels pretty soft. I'm afraid that with normal use it'll get scratches and realy look bad.
I used it on a couple a few years back. Looks good, but I find it too soft for scales unless it was riveted rather than pinned. Had a tendancy to curl when trying to flatten on a table sander. More trouble than it was worth to me. Certainly not for high end knives.
