Looks like you're in LA. Trader Joe's has their panko bread crumbs again, which is awesome.
While you're at Trader Joe's, buy their course sea salt and one of their plastic pepper grinders. (cheap)
Give the fish a healthy dose of the salt, pat it into the fish, then grind some pepper into the fish and pat that too.
stir up a couple eggs with a fork, dredge the fish in the egg.
In a shallow bowl or plate, dump a portion of the panko. Dredge the egged fish through it, and toss into a medium to medium high frying pan with canola, corn or peanut oil.
Rinse, repeat.
Alternately, find a good cajun rub, and rub the fish in that first, then pepper, then skip everything else and throw into a medium high pan for blackened cajun fish.
FYI, the key for a novice to avoid sticking is to let the oil heat up well first. The trick is to not start frying until the oil is just about to start smoking. Also you can run your finger under the faucet and flick a few drops of water into the pan; if the drops dance in one place, you're good to go. If they dance all over the pan, you're almost there. If the drops just sit there like a toad, you've got a long way to go before frying.
