Anyone Know How To Use Corel Draw???
Jerry Busse
Moderator
I need to scan some mil. insignias into Corel Draw in order to convert them to PLT Files.
If you know how to do it and you're willing to give me a hand, please email me at jerry@bussecombat.com. Send your phone number and I'll give you a call. If you're able to successfully walk me through the process. .. .You will earn a $100.00 Busse Combat Shop Credit!!!!
Thanks,
Jerry
viking313 said:
I use my Corelas to Draw all the time.....just have trouble staying in the lines!!! :p
bs!! you probably have one of those biggie boxes that i was always evvious of..... u know , the kind with the built in sharpeners, seven rows all lined up like a staircase. like the ones that cute lil gril had that sat in front of me in grade school. :p
i have one of the 10 straight line packs. :barf:
ok... trade time, what colors do you have? i only have the basic M&M kind of colors :(
Thanks,
Jerry
You have got to be kidding...right?
Do you have any idea how much graphic design specialists make per hour? :)
Jerry, ya need to keep with the market...wait a sec don't you have someone that does this stuff for you already?
use it every day....:)
there are better programs however.
Use vector draw with autocad if you can Jerry, it will give you a much better outline for what I am guessing is for laser etching or similar.
Then again, email me the logos and ye shall receive them back ready to rock & roll in a couple of days! :)
Jerry, Don't listen to these guys.....They've been sniffing too much of your crinkle-coat dust lately. ;) :D :D I haven't worked with recent versions of Corel Draw, but will give you what I know from a pretty old version.
Basically you are looking to convert a bunch of dots (raster data) that your scanner outputs into a bunch of mathmatical data describing boundaries and fill-colors (vector data) that Corel Draw uses to approximate the image represented by those dots.
Your scanner output is probably a raster file format like .jpg. You can import the .jpg scanner output image into Corel Draw. Once you've got it imported, Corel Draw has a conversion function that does the process of raster-to-vector conversion for you. Depending on the complexity of the raster image input, the conversion could take quite a while (half-hour or so for even pretty small files on the slow machine I worked on at that time). However, military insignia are pretty simple graphically speaking -- just a few colors laid out in fairly contiguous fields/areas.
NOTE: the vector output of the conversion on the older version of Corel Draw that I worked with usually needed a lot of tweeking to make it accurately reflect the raster image that was converted. The difference created by the conversion process was simply a matter of the conversion function needing to make a series of "best guesses" as it progressed. Those best guesses would each be off by a bit from the original raster data and, after a bunch of such guesses, the accumulated error represented a very noticable deviation from the original image.
Once the Corel Draw internal conversion is complete, you can save the vector data into whatever output format Draw is capable of creating.
There are also software programs like TraceArt or RasterVect that specialize in this type of conversion (raster to vector). But the time invested learning a new program that you'll use once (or even just occasionally) is a tremendous waste of time that could otherwise be spent depleting your CBL stash. ;)
i agree :rolleyes:
Jerry, just tell me the name of the unit and chances are pretty high I can get you a vector graphic of their insignias, emblems, etc. I have a friend and he is really fond of military insignias and he should have quite a collection on his Mac. Just give me a try :)
Best Regards
Mark23
christ! give me a bottle of johnny blue and i'll walk out there from idaho and do it for you :D
and on the way i'll go through iraq and get some revenge on those brain dead barbaric coxksucking mother****ing *******s :grumpy:
i was going to say earlier that it seems like you could just scan the picture, find the folder it scans to, and drag and drop the image into your corel work space. convert to whatever file you want through corel.
or, go to import file and do the same.
but i dont have corel draw, so i thought id probably be missing some steps... would love to be able to do the step by step bit though :(
Not sure what's intended here....but can add my input.
The only .plt file I know of is an AutoCAD generated plot file to be send to a plotter (HP DesignJet, OCE, KIP, etc.)
If that's what you need, I can do it for you - and will be a heckuva lot more accurate than Corel Draw. But you'll need to provide the scan.
Shoot me an email if you still need it, Jerry.
what!!! are you crazy man?????
don't tell jerry to shoot anything, he's a trigger happy kind of guy and is just looking for an excuse to blsst ANYTHING!!! :eek: :eek:
Thanks boys! I made this post and then had to leave town for Bourbon country . . . . I'm leaving again today. . . .
I'll be calling some of you and emailing others before Tuesday. . . . Thanks for the offers men!
All of you have been a great help. . . EXCEPT for Dark Hog who always manages to cause trouble at the trough!!!! And to think. . . I used to blame Porkerson for everything!!! :eek:
Now I blame Dark Hog!!!! :eek: :eek: :eek: . . ... .
Awwwww. . . . Who am I kidding?. . . . . .
I BLAME PORKERSON!!!!!!!
