Originally posted by btice .....Would the dust from a sanding project be better,
Definitely.
The finer the better.
And, But, Too..................
You can combine fine with course with lumps if you like;
but you need the finer dust to fill in gaps between the courser bits.
You said you needed to 'sculpt' some wood.
Does this mean your making a 'lump' of something and not doing a fill-in?
If so, you might consider the wood putty sold in home stores.
At least one brand use to be sawdust & glue.
Or make your own with non-epoxy.
Depending on the durability vs handle-ability(?) you need.
Consider, if you could make the first version of wax
(parrafin or other), you could make a plaster mould from it,
melt the wax out in a low temp oven,
then pour/push you 'wood' into it for a wooden copy.
If you plan to break the mold carefully to release the wood item,
you simplify the molding/casting process.
Or cast (or squish together) a shape close to the final product
and carve it (thinking something like a Dremal tool).
