Anyone tried the Ken Onion Blade Grinding Attachment for WorkSharp?
I got one... I don't do videos, but I can tell you it works well. No issues being left handed... there's clearance on both sides.
Worth it in my opinion, a great way to get a variable speed belt sharpener, (which brings some advantages), in a more compact package and lower cost than some of the alternatives. Their approach to setting the angle works well also.
I've done a variety of knife styles and haven't run across any issues... and have also made some minor tip repairs on the platen side that worked well.
Hope that helps.
i am also lefthanded :) isnt it a little inconvenient when you want to start the motor using you right hand - and hold the knife with the left?
The sharpener has a lock button for the power switch so, with the Blade Grinding Attachment, I just turn it on, lock the switch, and do the sharpening.
I also noticed that there appears to be a threaded hole in the bottom of the WSKO to allow it to be attached to a work surface. Nice.
Is the KO edition really worth twice the price of the original tho? I mean,for a noob (like myself),would one greatly benefit from the extra features? Thanks in advance :)
I watched a video ( don't remember where) and they said the hole was the size for a tripod. So you can take your sharpener with you.
I'm getting a Ken Onion WorkSharp. I see they have what is basically a freehand attachment.
Has anyone tried it yet?
If it's of any use I have a review of it in Post #2 (link) of -
Review - Work Sharp Knife & Tool Sharpener - Ken Onion Edition
It's not really pure freehand - but kind of a guided freehand -
in that the belt incline angle can be adjusted - and one only has to hold the blade horizontally to get that angle -
there is a horizontal reference plate - just lift up from that and maintain the horizontal.
It is quite easy and intuitive - after a few runs I found it as easy as keeping a blade vertical (like when using crock-sticks V-hones)
the huge advantage is one can see the blade edge and grinding.....
I also used it for quite an extensive modification/grinding to fix and re-grind a knife in post #19 (link)
Hope that helps.
Vincent
http://picasaweb.com/UnknownVincent?showall=true
http://UnknownVincent.Shutterfly.com
http://UnknownVT.Shutterfly.com
I think it's a quantum leap forward. I think if you got the original you'd eventually end up getting the KO Edition eventually.
Hope that helps.
Vincent
That was a great write up. Thank you very much.
Thank you for your kind words.
I should mention that for sharpening - it should not make any difference being right- or left-handed.
Since the knife is in one hand to grind/sharpen one side,
then the blade is flipped over, to sharpen the other side
and has to be held in the other hand.
So for sharpening - the knife is held 50%-50% in each hand
Vincent
Where can I get the blade grinding attachment? Seems it's only available from worksharp.
It's early days -
either not released or in very short supply -
or might even be produced on demand -
So I would imagine not quite generally available yet -
that's probably why it's only available from Work Sharp itself -
but at least it is available.
General availability may depend on demand/popularity.
Vincent
