Anyone try using an elf-choil with a firesteel?
I've been wondering if the small choil on satin GWs, Culties, or any of the other non-NM EDCs could be used in conjunction with a firesteel, either the smaller Scout-type or the larger Swedish Army-type? The diameters seem close in size. Or perhaps, with a small modification, could you use the choil notch with a firesteel? Opinions? Ideas?
I've done it with the little choil on my SHBA, and it did work. (I was glad, too, since I was showing off that I knew how!) :D ;)
If it is not throwing off great sparks, you could try a round file, or even sand paper.
One great area that works on certain designs is the "tail" on the Meaners/SS. If you have a coated version, and then strip it, the corners of one side were sharper. Worked like a charm on my old SS. Greatest part, you did not even have to take it out of the sheath to do it, and no where near the edge!
With a satin version, you will probably have to do some work, because they tend to have a small bevel to break the corners.
