Anyone used the Tormek wet grinder?
Hi,Would anyone who has used the Tormek please tell us what you think of it, and if there is anything better in this price range.
I was thinking of getting an Edgepro, but the Tormek is only a little more expensive and looks like it might be worth it. Here is a link to see the Tormek wet ginder
The same site has some really tempting Japanese water stones as well. This is a tough decision.
I've been looking at the Tormek grinder for several years, but only because I do a lot of woodcarving which requires constant sharpening of many odd shaped tools. I have never seen this grinder mentioned outside of woodworking (cabinetry, carving, turning) groups and magazines. I'm sure it would work great for a professional knife sharpener, but for most of us, it is just more than we need.
The Tormek is a Low speed water-cooled grinder (90 RPM) which is unlikey to heat up steel enough to change the temper. There are jigs available for many different types of woodworking tools (knives, chisels, planes, qouges, and woodturning tools. You can 're-grade' the stone from rough to fine. It has a built in leather stropping wheel.
I think it is a great tool, and is far better for the requirements of sharpening than many other grinders. It is expensive, however. And for just knife sharpening, I think it is a bit too expensive for my needs, although I think it is a good price for what it is.
As for waterstones, they work really well, but require a lot of maintenance. I have several, but most often just use three grades of ceramic stones dry (medium, fine, and ultrafine), followed by stropping on leather charged with chromium oxide (green polish). It is really very rare that I need the aid of courser stones. I have never used a grinder on a knife for sharpening.
If you have a lot of money to spend, and a lot of tools that need sharpening regularly, I think the Tormek would be a fantastic thing to have. I plan to own one someday. But for the needs of the average knife knut, it is more tool than they need.
Paracelsus
You will need the 'knife' jig for $38 more in additional to the straight edge fixture (chisels) it comes with. BTW, $398 is the Best price I have ever seen for this tool.
Paracelsus,
Thank you for your very detailed and informed response. I've gone ahead and ordered the three types of ceramic stones you mentioned, as well as a two-sided course/fine diamond stone.
I ordered these before I saw your post or I would have gotten the leather strop and paste as well. How noticable a difference does stropping make after using the ultrafine ceramic stone?
Erik
Stropping will not make an enormous difference after honing on an ultrafine ceramic stone. The main purpose is to align the microscopic teeth that make up the edge. All edges are really like saws at a small scale. Frequent stopping (or steeling) will keep the edge sharp for a very long time, reducing the need to re-grind bevels on stones.
Some people (like me) prefer a very fine polished edge that is optimized for push cutting (cutting wood). Others like to leave a relatively coarse edge on the blade which seems to help with some slicing tasks. In either case, stropping and/or steeling an edge will help keep it it good working order. I think Joe Talmadge (see his sharpening FAQs in the knowledge base section of this forum) recommends roughing up a very smooth shaving edge (push cut) with a few light strokes on a coarse stone to improve slicing by increasing the size of the 'teeth'. The optimal edge depends on the steel, the edge geometry, and what you are cutting. Good luck!
Paracelsus
