There was the Field Knife (FK) - probably one of the most sought after blades around.Hi all -
I’ve had an EDC and HDFK and both were great but I’m curious if there’s something in the middle?
Thanks!
Field knife
The Field Knife 2 is in development now. Look for a few prototypes by the end of the year and production early next year.
Also, the 6" Utility Fighter might fit the bill for some folks. Those are in production now and will be available by the end of the year.
For the smaller knives - FK2 and such - any chance of getting a run in a steel with better edge retention than 3V? M4 or Vanadis 4E, maybe? I'd prefer higher edge retention over toughness at that size...
We run the smaller knives as a plate martensite (rather than lath) variation of the Delta protocol. This was on the last Field Knife and is on our EDC. Have you tried it?
I haven't had a chance yet to try anything smaller/harder than the HDFK in 60-61HRC D3VI completely agree that edge retention is more complicated than just steel A vs. steel B, but I do think that the difference between D3V@62HRC, vs 4V@64HRC, should be readily obvious to most users - assuming, as you stated, that any edge loss is from abrasion and not chipping (e.g., using the knife on relatively softer materials).
In other words - I'm in for an FK2 in 4V![]()
I like 4V because it does combine good edge stability with good wear resistance. I think this has a lot to do with being fairly moderate in its alloy content (going from memory here but I think it's about 85% iron?) and its high working hardness. Also the alloy is well designed for a cutlery heat treat because it doesn't really stabilize retained austenite so badly that you're left having to use the secondary hardening hump which plays hell with edge stability in thinner sections. Given an optimized heat treat 4V is an outstanding choice for a small thin knife. But it does rust and it isn't extremely durable so it is a niche item. I like the stuff, but don't discount the harder variation D3V in the same application. It's probably a better balanced choice for most people. If you're accustomed to things like S30V or just the industry standard heat treatments of any steel, you're going to be pleasantly surprised.
