- Apr 13, 2007
I never see this one mentioned too much so figured I'd give it a go today !
This trap is designed to hold a noose onto a deers(or other hoofed animal)leg till the animal has struggled enough to pull the noose tight.
First job was to make the hoof hold part, this consists of two rings, one approx 6-8" and the inner ring approx 2-3" with sharpened sticks running through both !
By pitdog2010 at 2011-05-25
Now to dig a hole and set the trap on the top of it...
Next job is to set up the snare over the trap. The other end can be to a fixed anchor point or as I did here to a spring mechanism.
My simple trigger.
A shot of the whole trap although it's hard to make out.
All that's left is to cover the trap with ground litter.
My plan was to film me setting it off but I forgot to take my gorilla pod and although I did try filming with one hand it came out too poor to show !!!
What happens is the deer steps into the trap engaging the hoof hold section. As it raises it's leg the hoof hold is attached with the noose on the leg above the hold.At that point the noose may or may not have tightened, it doesn't matter though because the noose cannot fall off so it's just a matter of time as the deer attempts to escape befoer it does become tight.
Now the trap worked but not as well as I wanted due to the Cedar roots I used being a little too flexible. As I continued my hike I saw these dried vines and realised that they would have been much better to use...
These formed a nice solid circle, I guess you could also use thin branches and lash a few together with para-cord.
Not wanting to waste this hoop I made Blair witch type decoration and left it up to scare other hikers, LOL !
Off topic but this park has the biggest Miners Lettuce I've ever seen, not sure why it is larger here ?!!
My simple trigger.
