I have an inexpensive folder with a D2 steel blade. The factory bevel was > 15° so I reprofiled it to ~13-14° with the KME using the inclinometer on my phone. I finished with the 1500 grit diamond hone. Then, as usual, I added a 15° microbevel with the Sharpmaker followed by stropping. Though I have done this successfully with other knives, this blade still would catch on paper. The apex was shiny and I felt no nicks. Glancing light suggested some irregularity at the apex (? wire edge) which persisted after several resharpenings with the Sharpmaker rods finishing with almost no pressure as well as lightly running the blade edge perpendicular to a small block of wood.
Because I like the appearance and size of the knife I tried a light microbevel at 20°. The edge seemed sharper with no paper snags. I returned to the 15° setting and used enough passes (80 I think) with the brown rod to restore the original more acute microbevel. After stropping, the edge remains good with no snagging but still with a slightly visible ripple at the very apex.
I don't know what I did right and post this simply as a tribute to persistence in the presence of ignorance. At my level of inexpertise, I know this is just an anecdote but I ask other members of the forum for comments or possible explanations. The simplest would be that my reprofiling was incomplete, leaving an untouched apex, Sharpy notwithstanding, or leaving a roughness at the apex that could be removed only with a more obtuse angle.
Damn, I'm wordy. Apologies.
