tinman44
- May 13, 2008
CRAP I JUST NOTICED THERE IS A REVIEW FORUM, MODS CAN YOU MOVE PLEASE?
http://multitaskertools.com/info.html
I have recently been looking for a multi tool to carry in my chest rig. After looking around at some of the other designs on the market, I decided to give the multi tasker a try. This thread http://m4carbine.net/showthread.php?t=28046 is where my search began.
Initial thoughts:
This tool is built like a tank. It is a little heavy (11 oz), though considering the tools it replaces I would suggest it's not that heavy. The G10 grips are comfortable and secure. The tanto blade came hair popping sharp, I prefer tanto for this application for the straight edge. The knife also has a liner lock that is solid. There's a larue wrench 3/8" boxed, it works as advertised. Standard file with sharp chisel tip. Bent tip carbon scraper is handy and can be used in more than one cleaning application. I like the castle nut wrench but I couldn't test it since I have a magpul UBR, I would assume this wouldn't be used for torqing just for field tightening. There is also a front sight adjustment tool that doubles as a screwdriver with included bits. The shaft is long enough to reach the pistol grip screw, added plus for me. The bits are well made w/ball detent (hollow ground from high carbon steel) and most sizes are AR15 typically used sizes. Overall initial impressions are this tool is what I have been looking for. Lets get on with some pictures
Picture review:
G10 panels really set this tool apart from most multi tools on the market. The bolts are extremely rugged for my untrained eye, recently learned they are designed to look like the foward assist on most ar15 lowers
Simple needle nose pliers with wire cutter. Straight forward, essential.
Castle nut wrench. Not sturdy enough to torque, however plenty sturdy enough to tighten those unstaked castle nuts so your range day dosent end pre-maturely.
4 Prong front post sight adjustment as well as screw driver bit holder. The prongs on this adjustment tool do not bend like other sight tools I've owned in the past.
The bits are commonly used sizes in most AR15 accesories. (2 flathead, 1 phillips, T10 Torx, T15 Torx, plus 3/32, 7/64, 1/8, 9/64 and 3/16 hex bits)
The larue wrench.(3/8") I know what you're thinking "larue sent me one with my mount" well I understand this one comes already mounted in every Multitasker. Free with purchase of Multitasker
As you can see this tanto is for lefties. I bet if the designer was right handed then this wouldn't be mounted wrong
Liner lock. Locks up good, I would be willing to say all my folders have liner locks. Leatherman probably has a trademark on their multitool locks.
Chisel tip. Until I used this I had never cleaned out the bolt carrier.
The bent tip scraper has a perfect radius to it. I understand this was inspired by the Chinese traditional bamboo ear-wax pickers. I used to just scrape this crud off with a pocket knife, state of the art cleaning
Also gets down inside those hard to reach places in your BCG.
Heres a look at the shims. If I recall correctly the shims are brass instead of plastic.
I was told the case may be redesigned. I would like to see some Olive drab. I know digital is the new black but I still prefer OD.
Final thoughts:
This Multitasker fits my needs and does so in a compact durable design. The tools that fold away into this multitool cannot be carried on my chest rig like this can. In fact I would suggest to anyone that has a better design get producing, though I think you'll be surprised to find there is experience in this design. The designer also put the 1911 tool on the market and it has it's place as does this tool. I have other multi tools (leathermans) several in fact and they will stay where they are, though my multitool will be in my administrative pouch on my rig. Only suggestion I could come up with for the designer is to design a better way to get the sight tool out, perhaps a thumb catch of some sort. Also an OD case would be better for me. Knife seams like it is for lefties and this could be neccesary with clearances, kinda a non issue.
This is my first review and I hope it helps in some way. I have been wanting to write reviews for some time. I wish I could have had more in depth discussion, though I prefer the reader to see what I can show them with pictures. I have got to get a better camera and lighting. I hope to do a review on at least one of the other multi tools, my dad has the one on order that goes in the grip.
slide show of my product testing
http://img41.imageshack.us/slideshow/player.php?id=img41/4681/1245128928z98.smil
Initial thoughts:
Picture review:
Final thoughts:
