Arc-lite sheath questions
Greetings all you all, I have an Camillus Arc-lite neck knife with the kydex sheath. I really love this knife and would like to explore the possibility of somehow rigging it up to be used as a belt carry, either horizontal or vertical. Any ideas on how to do this, or where I can purchase a clip of some kind. There are two rivet holes on one side that I'm sure something can be attached to. Is there a mini Tek-lok available? What is a "J-clip"? Looking forward to your replies.
Easy one. Remove knife from sheath, cut 10" to 12" of paracord (play w/ length) & make loop through holes for neck cord/chain. Loop through belt loop & pass empty sheath through loop (should be close) & voila, you have a IWB static-cord carry that you can adjust. One potential drawback if you can even call it that, When you draw, the sheath most times clears the waistband for a couple of inches, but the blade should clear the kydex just past the beltline.
