cat_x29
I`m in the process of making an integral
type dagger out of ATS-34. Instead of removing stock from a thick piece of material,I`m going to weld the guard and hilt sections on to a flat blade using the GTAW(Gas tungsten Arc Welding)process. Yes
this is the backward(so to speak)approach to making this type of knife,but hey why follow the crowd.
I plan to use ATS-34 filler material to maintain the same color match when polished This will be basically an autogenious weld, and, I do have some concerns about cracking. I do know that some 300 series stainless steels and other alloys are prone to cracking problems when autogeniously welded.I have found nothing to indicate that this is a possible problem with ATS-34,...but?(any metalurgist/welding engineers out there??)
This will be my first attempt at welding a martensitic stainless steel but with a 400-600 degree preheat,interpass temperature control and postweld heat treatment,I think it should work.
Now if I just get out to the workshop and finish making the pieces.......!
RB
