Spencer Frazer
SOG Forum Moderator
- Apr 13, 2000
Thanks everyone for your enthusiasm for our new ArcLock and products. We are as excited as you are at being able to launch so many great products this year. I have been working on a superior lock for 5 years. It isnt so easy to come up with something unique, functional, and cost effective. The simple designs always get taken first, but in this case simple is what makes the Arc Lock great. Below are some of the reasons why we have introduced this innovation.
The ArcLock is basically a rotating cam that intersects the knife tang. Once engaged, the harder you try to force it closed, the more it wedges. Physics are a beautiful thing. This combined with ambidextrous one hand opening and closing, a very strong blade retention in the closed position (important safety issue) that is easily overcome, and a completely unique action sets it apart. When showing this lock we always invite the customer to "watch the dance" of the lock button which travels back and forth in a type of lunar fast motion. Check it out. Also did I mention that opening is like lightening. You can also unlock the blade (with a little practice) by holding back the button and flipping it closed in an instant. Easy come, easy go.
Independent testing by an outside laboratory of the ArcLock came back with outstanding results. The lock was tested with pressure applied 1/2" back from the tip on the spine of the knife and did not fail until 338 pounds of pressure was applied. That equals 1,183 pounds of pressure directly to the lock before it failed .a significant achievement.
The design of this lock is self-adjusting over time. As it wears, it becomes more secure with greater contact surface interfacing between lock and tang and the angle of interference becoming greater. Relative to fouling by debris, the open design allows the user to see directly into the guts to make sure that the lock has moved into the forward position. It also allows itself to be more easily cleaned and/or blown out.
Sergiusz: Thanks for the recognition of the unique Vision blade design. We worked hard at coming up with something that borders on sculpture and yet is so functional. We refer to the blade shape as a "geometrically facetted" blade design but we welcome everyones own interpretation. As a matter of fact, I am always listening to you the user, for your inputs on what you like. We at SOG try to have a unique perspective on all that we produce, from multi tools to folders to fixed blades and we continue to be customer driven. Although I have a very busy schedule, I will try and get back periodically to discuss our new offerings. Thanks for listening.
Spencer Frazer
Chief Designer
SOG Specialty Knives & Tools, Inc.
Spencer Frazer
Chief Designer
