Matt
A digital probe in your forge is the trick.
As for annealing a ramping controller on your ht treat oven is nice :d. You can noramlize, anneal, then sub anneal, do your work, then heat treat with confidence that the blade was back to where you started when the steel was fresh.
The 3v has a fast quench time. ImHO after several blades, a heavy quench oil may be the cure for this. I feel its like d2 and 440c . They can be oil quenched, air quenched, or salt bathed (mar quenched). Most of the books say that oil quenching will improve corrosion resistance also. If you heat treat 3v just normal out of the box it requires quench plates to speed the ms time.
Send an email matt,george Ill send the info.
Forging is great to save belts on stock removal. D2, and most ss are a bitch to forge. You have to make sure you dont hit the material under forging limits. The cpm steels come with the grain so refined I dont see the purpose except to save belts. Does it cost more (gas coal) to forge them? Belts may be cheaper and the results may be not so good if the process is not right to keep the grain refined . These steels are already great!
The 3v with a diff tempered heat treat seemed to improve performance on my end. That made more difference than forging. The edge was tougher. With the air quench on the back being about 50 rc with no quench plates and the edge being hard from the oil was the big difference. Works great!
420v and 440v can be salt bath heat treated.
The interupted quench (mar quench) makes a BIG differece in performance. D2 also.
The comment about forging powder metal is cool . Just did several billets with that process also.
You can mix your own steel combinations and forge them. Pretty sweet. Real nice for mosaic. You can mix your own carbon, nickle elements ect and forge the steel to your own specs. This stops the block welding weakness in mosaic.
I made a few springs from 3v. It works ok. It was the only 3/6 stock I had in the shop on that day so I just did it after I called Crusible for some information that is not on the spec sheet. I prefer 410 hc for springs though.
The first SIFU DA spring I made was 3v.
Whipps that big blade right out there
Web Site At
www.darrelralph.com
Happy Holidays!
[This message has been edited by Darrel Ralph (edited 12-01-2000).]
