Are Diamond Rods Forever?
blixxx
BANNED
Diamonds are forever but how about them rods? I just bought a Lansky Tactical Diamond Rod, how long or how many sharpenings should this things last me?
They can be forever (essentially) if you remember to avoid heavy pressure while using them. On a rod-type sharpener especially, the small contact area will focus a lot of pressure on a small portion of the edge, and on a very narrow portion of the sharpener itself. That can work to advantage (speed), if you're careful with it. The thing that shortens the life of a diamond sharpener is exerting pressure strong enough to rip diamond out of the substrate (usually nickel) holding the grit. It won't make the edge of the knife any sharper, either; just removes excess steel unnecessarily, and leaves the edge rougher & coarser than it should be.
For touching up a blade that already is in decent shape, but just a little dull, a diamond rod should put some teeth back into it within no more than 5 - 10 very light strokes. Rod sharpeners aren't the best option for complete re-bevel jobs, because there's so little surface area doing the work. Takes too long, and it also adds a lot of wear to the hone. A larger bench stone/hone is better for re-setting bevels, if need be.
David
