I think he means non-Khuk (shaped) not non-HI. Like the swords, farm knife, AKBowies, Kumar Karda, etc. not Khukri shaped. Im pretty sure HI differentially hardens eveything in the traditional manner. I have seen some that extend wider than others on straight knives and some like the AK Bowie that are hardened just like the Khuk shaped blades. You can pretty much tell after you get used to sharpening them. If needed you can run a file lightly across the edge and feel where its harder because the file wont dig in. It will slide across instead of cut. After you use the polished blades a while you can start to see the line where its hardness increases. In general if your buying an HI blade you can pretty much count on it being hardened where it needs to be. I have scores of them and they are all properly hardened. btw. A bit of lemon juice or vinegar will also show this temper line but will "patina" the edge as well. Do the file thing if you want to keep the mirror shine.Some are, some are not. You take your chances.
Well. back to the original topic - What about the Chainpuris from Chainpur that are offered on the DOTDs? I would assume that anything sold by HI would be properly differentially hardened / tempered?
