I'm wondering if I should get a arkansas or a diamond stone for sharpening. Also. Should I get it in fine or medium for sharpening. I will be using it in 1095 croc an if that helps. Thanks.
A decent quality Arkansas stone will likely work just fine on 1095. As mentioned earlier though, Arkansas stones will be much more limited, or ineffective, on more modern and wear-resistant steels, if you upgrade sometime. Arkansas stones tend to be very slow in more heavy grinding tasks, on modern steels. The hard Arkansas stones (black hard, translucent hard) can sometimes still be nice polishers on a wider variety of steels. Still slow, but can burnish & polish with some patience.
IF you do use diamond, use a finer grit; coarser diamond grits, for 1095 steel, would be too aggressive for most tasks, and it'll be very difficult to fine-tune a finished edge with anything coarser than a Fine or EF. A Fine diamond hone can even be used for re-bevelling small/medium-sized blades in 1095. In fact, I prefer such a hone for these tasks on this steel; it's very fast and leaves a very uniform grind pattern and crisp bevels, with a minimum of effort.
And a strop with some aluminum oxide (white) or chromium oxide (green) compound goes very well with 1095 steel.
I've recently been using Fine/EF diamond hones to re-bevel smaller traditional pocketknife blades in carbon steel or simple stainless like 420/440 varieties, followed by stropping with white compound, which cleans up burrs and polishes very fast. Sometimes use green compound on a strop, but more often follow the white by going straight to a bare leather belt. This sequence has become one of my favorites for steels like these.
David
