- Jan 18, 2011
I saw the expensive version of the waistline on Youtube, and it looked like an awesome, large Boker Kwaiken.
This one has S35v, and the anodized titanium handle. $187
I went to KnifeCenter, and snagged the cheaper D2, "carbon fiber" version below for $65.
"If it looks too good to be true, it probably is". I was definitely disappointed. I'm not sure whether it will be a keeper, or a gift.
It looks, and feels like a high quality flea market knife.
The handle is smooth as glass. It appears to be plastic with a carbon fiber pattern beneath the surface. The handle is thick, and square with sharp metal liner edges (full liners).
The cheap looking clip is a 'deep pocket' style, but it is mounted 3/4" from the end?? The knife is SUPER loose in the pocket, even with jeans. The slick handle is probably mostly to blame.
The lanyard hole is way too small for 550 paracord?! The lanyard tube has VERY sharp standard screwdriver(?) cutouts on both sides. Guess what you grab on to when you pull the knife out of your pocket?! It will break the skin.
The blade is centered, with no play in any direction. The flipper, and ceramic bearings deploy the blade fast, and smoothly. The flipper is not jimped too aggressively. There is a weird rubbing sound. Not grittiness. Is this normal for ceramic bearings? If you open and close the blade super slowly you can also feel the slight 'bump, bump, bump' of the ball bearings. The blade spine is VERY thick (thick handle?) I like that. I hate paper-thin blades.
The stone washed blade, and pivot screw look very good. The liner lock is early, and not sticky like the some other Chinese CRKT, Kershaw knives I own.
It shaves arm hair, and appears to have a strong, but pointy tip. The grind is decent.
- Blade Length: 4.06" (103.0 mm)
- Cutting Edge: 3.84" (97.5 mm)
- Closed Length: 4.92" (125.0 mm)
- Overall Length: 8.98" (228.0 mm)
- Blade Material: D2 Carbon Steel
- Blade Thickness: 0.15" (3.8 mm)
- Blade Hardness: 58-60HRC
- Blade Style: Upswept
- Blade Finish: Stonewash
- Handle Material: Carbon Fiber
- Handle Thickness: 0.5" (12.7 mm)
- Locking Mechanism: Liner
- Pivot Assembly: Ceramic Ball Bearing
- Pocket Clip: Tip-Up Right/Left Carry
- Weight: 4.1 oz.
