- Mar 5, 2003
quote:
With the current engineering involved in knive making and depending on grind, thick knives are, pound for pound, and blade length for blade length, than axes.
Would you care to show some proof of that assertion? I believe it to be absolutely false. Look at every lumber operation, where a chopping tool is used on hard woods, it is an axe. A long, thin knife (called a machete) is used to clear brush. That is where blade length is important. Even for cutting the branches off the trunk (called "limbing") an axe is used.
For chopping wood (since you specifically stated "much more efficient choppers"), the axe is much, much better suited. Espeically when you have listed the criterea of "blade length for blade length", since an axe has a blade length (called a "bit") of around 4 inches or less, whereas big knives can eaily be twice that much or more, Ten inches is not uncommon for big knives.
The blade length is actually detrimental to chopping performance, as you increase the surface area being hit by the edge, you decrease the concentration in force.
Basicly, it is silly to argue the Knife Vs. Axe debate here, it has been argued for many years, and the axe proponents always win.
Further, while there are good knives out there, there are also excellent axer makers such as Gransfors Bruk.
quote:
First, and I'll leave it at this... Jerry may be a bit better read than you might suspect.
I don't doubt for a minute that Jerry is very well read. I don't claim to be more educated in general, or about knives than Jerry. Jerry is a college graduate (MSU IIRC), and I barely graduated high school. He is a reknowned knifemaker, and I don't doubt for a minute that he is a capanble outdoorsman in his own right.
But, I have read the classic outdoorsmen so many times, and it is an area that interests me so much, that I am sure, very sure, that I know what I am writing about here.
IN the end, the classic outdoorssmen, such as Nessmuk, would like the A.G. Russel Deerhunter as a belt knife, not the "buffallo Solider"
You don't have to like it, or agree with me, but the plain words of these outdoorsmen, as memorialized in their writings, clearly indicates a dislike of thick knives.
quote:
Second, I'm guessing that Jerry was reffering to the look of the blade as "Nesmukian" or Nesmuk-esque... Not that it was truly a blade that Nesmuk would have endorsed.
Perhaps. Their is simply no way that Nessmuk would have endorsed this knife.
Perhaps another label would be better suited.
Mike,
I agree, BTW, that the debate over Knife vs Axe is silly. But since you brought it up, and since I'm not one avoid a good argument... I'll indulge you. And since we're discussing the "fact" that Axe-Users "win" the argument hands down... We should probably define the term "Win".
If you are defining "winning" in terms of denial of the physical realities and a complete unwillingness to admit that you are incorrect when faced with facts that contradict your opinion... then I guess "win" is the correct term.
Further, the proof I can offer is experiential and based in basic physics. It is simply this: If you apply the same force to a knife blade (regardless of edge length) and to an axe, the knife will, by virtue of geometry and other physical attributes, penetrate deeper into your test material... in this case, wood. That is not to say that you cannot chop with an axe. You most certainly can. If you apply enough force and leverage you can chop with a rock. That doesn't make it the most efficient chopping tool.
Next point: Not once did I say that you didn't understand the writings of the "classic writers". What I did say is that just because they are considered classic in some circles does not make them infallible by default. Read and believe what you like. Dislike thick knives all you like... but don't try to pass that dislike off as proof of any sort.
And lastly: Didn't I say that I believed Jerry's intent was not to present the knife as something that Nessie would have endorsed? If you restate an opinion, in the same words and same context, that is not a disagreement. That is an affirmation. Did you actually read what I wrote and you quoted before you restated it verbatim?
Yours in argumentative, logic based, Nuclear blade debate.
