most knife makers have there own personal favorite steel they use, work with. also if they have worked with it long enough usually they have a process that works for them or they think brings more out of the steel, some may call this voodoo. i do not. i personally love to hear or see the hard work people put into there heat treats or voodoo.
what is your voodoo?
from start to finish what is the process you use on your steel of choice or any steel that you use
normallizing
thermal cycling
annealing
hardening
the temps you use
soak times
inbetween times
cryo
temper temps
temp of oil you quench in
type of oil you quench in
even the temp of your room temperature inbetween tempers.
and most of all what type of steel.
this thread is for helping better the world of heat treating
help is alway wanted BUT PLEASE DO NOT TELL SOMEONE THAT THEY ARE WRONG!!!
giving advise is different then saying (that wont work)
i am sick of the fast boring heat treating processes.
normallizing
thermal cycling
annealing
hardening
the temps you use
soak times
inbetween times
cryo
temper temps
